Air compressors deliver up to 18% efficiency improvement
By Mike Santora | March 16, 2016
Ingersoll Rand, a leader in compressed air and gas systems and services, power tools, material handling, and fluid management equipment, has introduced the new RS30 and RS37 models, the first in a series of next generation oil-flooded, rotary screw air compressors.
The Next Generation R-Series Air Compressors deliver performance and enhanced reliability, lowering operational costs for those in need of general purpose plant air in support of assembly, manufacturing, mining and conveying applications.
Ingersoll-Rand-compressor-imagePerformance and Technical Benefits: Efficiency, Reliability, Air Flow Capacity
The new air compressors improve performance through a state-of-the-art airend, which is the heart of every air compressor. The new airend design was developed through analytics and modeling, and includes an improved rotor profile that provides up to an 18% efficiency improvement compared to previous models.
The new rotor profile also contributes to airflow capacity, delivering up to 15% more airflow than previous models. The improved airflow creates a more reliable air supply, reducing downtime and increasing production efficiency, even in extreme operating conditions. An enhanced bearing arrangement and sealed drive system further improves performance and reliability while reducing the need for maintenance.
The motor design and high and low ambient temperature options help the Next Generation R-Series for operation in challenging environments, helping to protect valuable investments.
The newly revised, analytics-modeled airflow and piping system further contributes to energy efficiency by ensuring a low pressure drop. This saves energy and lowers utility bills while minimizing sound output to create a safer, more comfortable work environment.
The Next Generation R-Series air compressors are compatible with the Xe-series controller which allows easy remote access to, and control of, the compressed air system using any current, common web browser. Users can receive information on compressor performance and events by email, adjust compressor settings remotely and program compressors according to specific events through real-time clock schedules. This means users can automatically start or stop compressors for shift changes or preventative maintenance.
The new series of compressors also enhance reliability with Progressive Adaptive Control (PAC) systems software that continuously monitors performance parameters and automatically adjusts settings to the application’s needs. The adaptive controls provide built-in performance analysis for a wide range of load requirements, thus reducing downtime risks.
Next Generation R-Series compressors also save customers money on equipment and operations by ensuring that discharge air powering equipment carries a minimal amount of moisture, which reduces the dependence on large downstream air dryers.
Ingersoll Rand
www.ingersollrandproducts.com/NextGenRSeries
Pneumatic Tips
Filed Under: Pneumatic Tips
Tagged With: ingersollrand
FPTC keynote: the evolution of advanced automation
pmmilogo
PMMI releases newly revised B155.1-2016 packaging machinery standard
mcdlu-positioner
Digital positioners for fluid-power actuators
hotrodders
Firestone Industrial Products team to compete in Annual Engine Challenge
