Air differential pressure gauges
By Leslie Langnau | February 27, 2019
For use with air and compatible non-combustible gases, ProSense DGA differential pressure gauges are used to measure and display difference in air pressure between two reference points in inches of water. Applications include air/gas flow indication, filter monitoring, cabinet purging, room positive or negative pressure status and more.
These high-quality gauges feature an industrial grade black die-cast aluminum case with two high pressure and two low pressure connection ports (1/8″ female NPT), and a 4-inch (100 mm) white aluminum dial with black pressure markings.
Gauges are available for pressure ranges up to 150 inches water column (WC) and zero-center ranges from +/-1 to +/-15 inches WC with 2% full scale accuracy. These gauges have an ambient high temperature tolerance of -40°F to 140°F (-40°C to 60°C) and a process temperature range of 14°F to 140°F (-10°C to 60°C).
AutomationDirect
www.automationdirect.com/differential-pressure-gauges
Filed Under: MOTION CONTROL
Tagged With: automationdirect
