    • Subscribe!
Airbus uses LMS Test.Lab to Improve and Streamline Flutter Analysis Process
By Frank Tobe | September 5, 2014
SiemensGetting new airplanes tested and approved for flight by various government agencies can be a Herculean task for manufacturers and their design teams. Extensive testing—much of which is done using computer-based analysis tools—is required to validate designs in the most cost-efficient manner. Let’s take a look at how Airbus used LMS Test.Lab Flutter Analysis software from Siemens PLM Software to streamline its flutter analysis process.
Streamlining Flutter Analysis
Modal identification methods used during flutter testing—like aircraft characteristics—have evolved to enable correct parameter identification. Frequencies and damping value estimations have to be as accurate as possible in order to define the aircraft fluttering margins used during those first critical in-flight test campaigns.
Flutter testing can be broken into three segments: real-time; near real-time and offline. In-flight real-time test campaigns are used to acquire live data during the test flight, mostly as a safety check to continue the flight envelope. The near real-time testing focuses on rapid modal estimation to determine the overall safety of the flight and the flutter test program. The offline testing deals with the finer analysis of the recorded flight data and final report production.
LMS Test.Lab Flutter Analysis software from Siemens PLM Software enables the user to validate data efficiently and effectively, automating the use of LMS Test.Lab Operational Modal Analysis software. It offers a full package with all the required functionality, such as data preprocessing, modal parameter estimation, mode shape animation and result validation.
The Airbus flutter team in Toulouse, France faced several challenges working on the Airbus A380 campaign, but these were issues they had faced before with the Airbus A340 flutter campaign: high modal density and similar mode shapes, both placed in a low narrow frequency band.
In terms of modal identification, these new precise requirements called for a better-defined and equipped testing installation, which meant digging a bit to find the right kind of process. Measured data needed to be recorded at enough locations with high enough quality to improve power spectra and transfer function estimates and avoid spatial aliasing when working on deformed aircraft shapes. This required some innovative thinking and serious process validation compared to current techniques.
Building on EUREKA FLITE projects
Since 2001, Airbus France and Siemens PLM Software have been cooperating on several European Research Cooperation Agency (EUREKA) projects called “FLITE” (Flight Test Easy). An intergovernmental initiative to support market-oriented European research and development, the EUREKA FLITE projects focus on bringing new and powerful tools to structural engineers and aircraft designers, improving the quality and usefulness of data gathered during flight testing.
The FLITE consortium gathers world-ranking aircraft manufacturers and technology providers from France, Belgium and Poland. The FLITE projects offered a unique opportunity to confront new, advanced algorithms with challenging real-life aircraft data.
Finding the right data
In late 2007, Siemens PLM Software and Airbus agreed to start a project to evaluate LMS Test.Lab Polymax software, an analysis component of LMS Test.Lab Structures software, as a key solution to achieve high-quality offline, in-flight data processing for flutter analysis. LMS Test.Lab Structures is a complete solution for experimental and operational modal analysis, combining high-speed, multichannel data acquisition with a suite of integrated testing, analysis and reporting tools.
Siemens PLM Software is known for its modal testing experience and scalable solutions, from supporting impact testing on small structures to large test campaigns using multiple shakers and hundreds of measurement channels.
Siemens2
Airbus used LMS Test.Lab Flutter Analysis software from Siemens PLM Software to streamline its flutter analysis process for its 525-seat Airbus A380.
In the past, the flight test department of Airbus France performed data analysis using its in-house, near real-time analysis package, and transferred the results together with the raw data to Airbus Germany, where the numerical flutter predictions were correlated with actual flight tests. However, Airbus France felt the need to conduct further in-depth data processing so that it could transfer more complete results to Germany.
“Clearly, we needed a solution that would improve the alignment between online in-flight analysis occurring in Toulouse and the postprocessing completed in the design center in Airbus Germany,” said Jean Roubertier, flight test department aero-elasticity expert at Airbus. “At this stage, we’re very pleased with the results. LMS Test.Lab is able to provide us with the right type of results.”
Realizing record-breaking data acquisition
The 525-seat Airbus A380 is the largest commercial passenger aircraft in the skies today, so it isn’t surprising that simply due to its sheer size, the acquired in-flight testing data is record-breaking as well.
“With more than 100 sensors, that was one of the largest setups for an in-flight flutter test campaign that I have ever seen,” said Bart Peeters, Siemens PLM Software project manager. “Also, the amount of tests under different flight conditions was impressive. The resulting database is immense and efficient processing and report generation capabilities are required.”
The Airbus Flutter team in Toulouse performed a variety of excitations, including control surfaces sine sweeps and pulses. Pulses are currently used to assure crew and aircraft safety, whereas sweeps are used to work out more accurate results, enabling the update of theoretical finite element (FE) models. Thanks to integrating pulses into the process, the duration of flutter flights has been considerably reduced.
The basic concept behind the project was to compare classical experimental modal analysis (EMA) with LMS Test.Lab Operational Modal Analysis software. In classical EMA, the control surface excitation and aircraft response signals are converted to frequency response functions (FRFs). During the actual flight, other excitation sources, such as turbulence, are present. Sometimes this results in noisy FRFs. For example, an aircraft tail response sensor receives a rather limited contribution from the wing excitation. Therefore, the idea arose to neglect the excitation signal and apply operational modal analysis (OMA) to the aircraft acceleration signals.
Siemens3
LMS Test.Lab can be used to provide a clear picture with techniques that produce accurate analysis results, even from rather noisy data, which gives clients like Airbus a true competitive advantage when it comes to offline test processing.
“We actually achieved better results using OMA than with classical EMA,” said Miquel Angel Oliver Escandell, a member of the Airbus Flutter team. “We found more modes. The synthesis was better with higher correlation and fewer errors, and the in-flight mode shapes looked much nicer. This was thanks to the amount of sensors we used and the OMA capabilities of LMS Test.Lab.”
De-noising the data
Even with projects of this scale, there is always noise in the data that needs to be managed. LMS Test.Lab can be used to provide a clear picture with techniques that produce accurate analysis results, even from rather noisy data. This feature offers clients like Airbus a true competitive advantage when it comes to offline test processing.
“We found that the exponential window, which allowed for cross-correlation calculations, was a good de-noising tool for our in-flight data,” said Escandell, who worked on the project for a year. “And, the validation tools, such as correlation levels, MAC matrix and mode shape complexity (MPD and MPC criteria) are complementary in regards to real-time identifications performed during flutter tests.”
During the comparison testing, the flutter team at Airbus used LMS PolyMAX during sweep excitations of the aircraft. The results, based on using an exponential window of 5%, appear to be good, supplying high synthesis correlations (98% using just two references) and clear stabilization diagrams.
“We’ve been extremely impressed by the flutter analysis results and the way that LMS Test.Lab software is able to handle the challenges of processing the immense amount of Airbus A380 in-flight data during the offline analysis,” said Roubertier.
Airbus
www.airbus.com
www.siemens.com
Filed Under: TECHNOLOGIES + PRODUCTS, ALL INDUSTRIES, Software
Tagged With: Siemens, airbus
CIT
Relays feature 1.8-mm contact gap to meet IEC safety standards
New economical linear modules for lighter loads
Ethernet remote I/O modules add Conditional Logic Computing
Self-contained actuator for a variety of applications
    • Subscribe!
