Airpel AB Air Bearing Actuator
By Design World Staff | July 23, 2008
Airpot Corporation’s Airpel Division has introduced the Airpel-AB Air Bearing Actuator that combines air cylinder like linear actuation with zero friction air bearing technology.
The Airpel-AB provides “force without friction” which is made possible by a specially shaped stainless steel piston that is precisely fitted to a borosilicate glass cylinder. The introduction of pressurized air into the air bearing‚’s cylinder creates a true air bearing airflow effect around the piston.
With as little as 5 PSI of air applied to the cylinder, the same air that drives the piston also produces a stiff cushion of air to support the piston and prevent it from contacting the cylinder wall.
The result is an air cylinder that delivers virtually unlimited piston life, no lubrication and clean operation. In addition, the output force of this friction-free air cylinder is reduced only infinitesimally by movement of ultra-low friction ball joints used to connect the rod. These unique qualities allow Airpot Corporation to guarantee that the Airpel-AB will exceed the life of any machine or instrument in which it is installed.
Airpel-AB air bearing actuators are available in metric models with four bore diameters and ten standard strokes to provide precisely repeatable driving or supporting forces from 2 grams to 58 kg. Operating temperatures range from -20 C to +90 C.
www.airpot.com
Filed Under: Actuators, Bearings, Motion control • motor controls
Tagged With: airpot
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
