AL60-100 Series Power Supplies from TDK-Lambda
By Patrick Curran | November 2, 2011
TDK-Lambda Americas has introduced a new line AC-DC power supplies that are designed for LED lighting, signs and display applications with output ratings of 60, 80 and 100 watts. Both constant-voltage and constant-current models are available. These new AL60-100 series are LED drivers/supplies that meet IP66 (splash proof) standards and operate with universal power inputs from 90 to 305VAC with no derating at low line. Power Factor Correction (PFC) is included.
TDK-Lambda-AL60-100-Power-Supplies
The constant-voltage models (ALV series) are available with 12V, 24V or 36V outputs. While the constant-current units (ALC series) provide from 1 up to 4 Amps with DC out-puts ranging from 6 to 48V, depending upon model. All models are convection cooled and can operate with ambient temperatures from -30°C to +70°C (deratings above +50°C). And, they are guaranteed to start-up at very low temperatures down to -40°C. Typical output efficiencies are 85-90% under full load. Other standard features include overcur-rent, overvoltage and overtemperature protections. Units are housed in rugged Lexan 920 plastic cases that measure 1.36” H x 1.70” W x 9.49” L.
These power supplies/drivers meet EN55015-B, EN55022-B, CISPR 22-B and FCC-B EMI/EMC standards (conducted and radiated emissions). In addition, these units are safety agency approved to UL8750 (Class 2), EN61347-1, EN61347-2-13, CSA C22.2 No. 60950-1 and carry the CE mark. All supplies have a 3-year warranty.
TDK-Lambda Americas
http://www.us.tdk-lambda.com/lp/products/al-series.htm
Filed Under: Electronics • electrical, Lights • signal lamps • indicators, Power supplies
molex-premo-flex
