Alpha Wire Grows EcoGen Product Line
By Editor | January 17, 2013
Alpha Wire has unveiled the latest additions to its growing environmentally friendly product offering: EcoCable and EcoFlex. Utilizing the innovative 100% recyclable MPPE insulation found in EcoWire, EcoCable and EcoFlex are designed to be up to 65% lighter and 47% smaller, with up to 91% lower outgassing than traditional PVC cable. The two control cables are nonhalogenic and contain no heavy metal pigments, allowing them to meet RoHS and Waste Electrical and Electronic Equipment (WEEE) requirements.
EcoCable offers space savings of up to 47% compared to traditional PVC control cable. For example, a 22 AWG PVC insulated cable has a diameter of 0.502 inches (12.75mm). The equivalent EcoCable has a diameter of 0.219 inches (5.56mm). Its counterpart EcoFlex offers space savings of up to 32% versus PVC and is rated for up to 1 million flex cycles.
Ecocable
The initial EcoCable offering is a UL AWM 21510 and CSA Rated cable available in sizes ranging from 24 AWG (0.28mm²) to 14 AWG (2.08 mm²) available in 100ft and 1000ft lengths. EcoCable is suitable for use in NFPA79 applications and is RoHS and REACH Compliant. Its temperature range of -50°C to +105° exceeds that of standard PVC cable.
EcoFlex is a UL AWM 21819 and CSA Rated flexible control cable available in sizes ranging from 28 AWG (0.09mm²) to 10 AWG (5.32mm²). It’s offered in 100ft and 1000ft lengths, with bulk available for larger quantities. With up to an 8x flexing bend radius and rated for up to 1 million flex cycles, EcoFlex is suitable for use in NFPA 79 applications and is RoHS and REACH Compliant. Its temperature range is -40°C to +105°C static, and -5°C to +105°C while flexing.
Alpha Wire
www.alphawire.com
Tagged With: alphawire
