Aluminum Cabinet Door Handles
By Design World Staff | April 11, 2008
NEW BERLIN, WI – J.W. Winco, Inc.announced it now offers metric size Aluminum Cabinet Door Handles with open- or closed-ends.
Made of cast aluminum with black powder coated pebble finish, the handles have tapped holes for mounting. These open-end or closed-end type handles are mainly used in applications requiring a sturdy and rugged grip. A special characteristic is the thumb rest pad on the front leg. Both versions are 162 mm (6.38”) in length.
Because of the dual mounting holes, there is a choice of two center hole mountings on the closed-end handle. Due to the dual mounting holes on the open-end handle, the handle is secured tightly into position after installation.
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
