Aluminum Electrolytic Capacitors in Reduced Case Sizes
By WDD Staff | August 25, 2014
NIC Components (Melville, NY) announced the addition of NRB-XG series of long life rated radial leaded aluminum electrolytic capacitors in reduced case sizes. NRB-XG provided component downsize solution in 6.3, 8, and 10 mm case diameters, for use in high voltage power applications including electronic lighting ballast circuits. Long life rated at 8,000 hours at +105°C, NRB-XG is available in 1.5 ~ 27 uF in 200 and 400 VDC ratings with operating temperature range of -40° ~ +105°C. Additional features include:
  • Long life @ 105°C, 8,000 hours.
  • High voltage up to 400 V.
  • Reduced size.
  • High ripple current.
For more information, visit www.niccomp.com.
Filed Under: Capacitors, M2M (machine to machine)
Machine Learning for Sensors
