Since its introduction in 1971, the Ameriflex multiple convoluted diaphragm coupling has been a standard for life and reliability in high performance machinery applications. Today, by using the latest design and manufacturing technology, Ameridrives Couplings is able to offer increased diaphragm coupling performance without compromising reliability.
Advanced analysis and manufacturing processes have produced increased ratings without reducing safety factors. The use of the latest finite element analysis methods verified by strain gage and dynamic testing has allowed for a more precise calculation of the Ameriflex diaphragm stresses.
Designed for infinite life High torque to diameter and weight ratio
Diaphragms are 15-5PH stainless steel
Diaphragms are shot-peened for improved fatigue strength and corrosion resistance
Low bending moments and axial force result in lower bearing loads
High axial travel Multiple separated diaphragms provide a built in safety feature.
Failure is gradual with reduced offset stress in remaining diaphragms
Design flexibility by changing the number of diaphragms
Field replaceable flex-element assemblies API-671 Compliant
Ameridrives
www.ameridrives.com
Filed Under: Coupling Tips
