(North Bergen, NJ)- Amperite announces the addition of their new, 100% Solid State, SEQ Series sequential recycling relays to their expansive product line of solid state and thermal time delay relays, flashers, timing and industrial controls.
The SEQ Series sequential recycling relays may be used to alternately switch 2 to 5 loads in a repeating sequence with frequency and duration adjustability. Load switching is accomplished by a solid state device. Typical applications for the SEQ Series include ON/OFF cycling for equipment burn-in test, automatic cycling of electrically operated devices, such as signs and lighting controls.
The SEQ Series timers have a maximum load current of 5 amperes; operating temperature range of -30º to 70º C and voltage drop of 2.5 volts RMS or less. AC units are available in voltages of 12, 24, and 120 volts with power requirements of 5 VA or less. DC voltages of 12, 24, 36, 48 and 110 volts are available and have a power requirement of 5 watts or less. DC custom voltages are also available.
User specified, factory fixed timing or user adjustable timing is available, over a ratio of 10:1 anywhere within the range of milliseconds to minutes, by means of a built-in DIP switch.
: Design World :
Filed Under: Relays
