An exoskeleton’s drive technology that’s got your back
By Mike Santora | November 16, 2021
45108_SR_Motor_2560x1500
In the Japet.W exoskeleton, four DC-motors with precious metal commutation of the 1524…SR series supply the supporting force for relieving the spinal column.
Adverse strain and continuous overloading of the spine are the most common causes of chronic back pains. The excess strain can easily be avoided by observing a straightforward rule: always lift loads with the knees while keeping the upper body upright. However, in daily life and with many jobs, this rule can be difficult to follow. Helping a patient out of bed, lifting a postal package out of the car, handling heavy parts in a production process, or working with heavy, portable machines on a construction site can make it difficult to keep back strain in the ergonomically correct range. The lifted weight then unavoidably presses on a flexed spine.
The leverage effect can be devastating here: depending on the degree of bending, a 10-kilogram package can press an equivalent force of up to 50 kilograms on the lumbar discs of the lower spine. While these natural shock absorbers made of fibrocartilage are exceptionally tough and resilient, they age over time and, when constantly subjected to improper strain, can wear prematurely: they shrink, the damping effect subsides, and the adjacent bone tissue also changes, often with painful consequences. In the case of a slipped disc, the intervertebral disc ruptures, the core slips out, and presses painfully against the surrounding nerves.
“If the excess strain cannot be consistently avoided, measures that provide relief must be considered,” said Antoine Noel. In 2015, the robotics engineer, together with Amelie Blondeaux and Damien Bratic, founded the company Japet in Lille. “Our objective was to develop an active support corset for the lumbar spine. Undesirable strain should be compensated for by motor power, thereby protecting the intervertebral discs.”
45108_Exoskelett_1
The leverage effect can be highly debilitating: depending on the degree of bending, a 10-kilogram package can press an equivalent force of up to 50 kilograms on the lumbar discs of the lower spine.
Relief through actuators
The result of their work is the exoskeleton Japet.W. It consists of two belts connected by four actuators — two on each side of the body. The upper belt supports the back and the lower belt is seated on the hips. The actuators are so-called series-elastic actuators (SEA). They “feel” a force acting upon them and use their own motor power to counter it.
Their most important elements are a motor, a lead screw, and a spring. A potentiometer measures the applied force, for example, if the wearer of the exoskeleton bends forward and picks up a weight. This measurement signal puts the motor, coupled to the drive lead screw by a gearhead, into operation. The turning of the lead screw transfers the motor power to the spring. It presses from the lower belt on the upper belt, supports the upper body, and relieves the lumbar spine. For the level of relief provided by the exoskeleton, the wearer can select from four levels. The controller and the battery of the device are integrated into the double belt.
“The hips experience only a slight additional strain as a result of the added pressure; they are, in any case, able to withstand even heavier weights without problem,” said Noel. “The force that acts on the lumbar spine is, on the other hand, greatly reduced. It is, above all, the excessive strain on the intervertebral discs while in a bent position that is significantly reduced or avoided completely. At the same time, the position of the upper body is also improved.”
Micromotors lift four cars
The founders of Japet first met FAULHABER at a trade fair. At that time, their company was still a technical testing lab in a side room of a clinic in northern France. The first sale was still in the distant future. In their first test devices, the three young entrepreneurs had installed inexpensive and noisy motors that could be controlled only poorly. The experts from FAULHABER took a liking to the ideas of the young engineers. They supported them with intensive consulting and prototypes of high-quality motors that could meet the needs of the demanding application. “That played a big part in making our product ready for series production,” emphasized Noel.
45108_Exoskelett_2
The exoskeleton Japet.W. consists of two belts connected by four actuators — two on each side of the body. The upper belt supports the back, and the lower belt is seated on the hips. The actuators are so-called series-elastic actuators (SEA). They “feel” a force acting upon them and use their own motor power to counter it.
In the Japet.W exoskeleton, four DC-motors with precious metal commutation of the 1524…SR series supply the supporting force for relieving the spinal column. Responsible for the load transmission are the planetary gearheads of the 15A series with a reduction of 52:1. Because the device is worn on the body, every gram matters here — at 18 g per motor, the drives account for just a fraction of the total weight. Nevertheless, they are strong enough to relieve the intervertebral discs of the weight of three to four medium-sized cars over the course of a workday.
The Japet.W has now been on the market for over a year. It is already used in numerous industries, including the railway industry, construction, and medical care. Its use serves to counter the possible development of chronic back pain. It is also used by people who have already developed this syndrome and are searching for a way to continue working. “75% of all wearers who had previously developed back pain while working report from an effective reduction in pain,” emphasized Noel. “That is a noteworthy value from a medical perspective, especially as chronic back pains are a persistent and difficult condition to treat. Because we all tend to work longer and because the know-how of the older employees is becoming increasingly more valuable, the exoskeleton has great potential from an economic vantage point as well.”
Faulhaber
www.faulhaber.com
Filed Under: Drives (dc)
Tagged With: faulhaber
