The WORX Nitro 20V 3-Speed Impact Driver is the go-to tool when it comes to tough assembly jobs, especially those with repetitive assembly work. It’s an asset when building decks, swing sets, benches, picnic tables, raised beds, and other projects. The driver is also handy for removing stubborn or rusted fasteners.
The WORX Nitro 20V 3-Speed Impact Driver features digital keypad to change the speed and impact rate electronically. Learn more in this video.
The new 3-speed driver features a digital keypad to easily change the speed and impact rate electronically. Outfitted with a high-performance brushless motor, the driver runs 50% longer and is 25% more powerful than conventional brushed motors.
This tool is equipped with high-efficiency brushless motors that run cooler with less friction and heat buildup than conventional motors with brushes, resulting in smooth, reliable, maintenance-free operation — with 10 times motor life.
This hard-working driver has a 1/4-inch chuck and only accepts hex-shanked bits. These bits are gripped evenly on all six sides by the chuck to prevent slippage. Hex-shank 1/4-inch bits are widely available at hardware stores and home centers.
The tool features three speed ranges of 0-900, 0-2400, and 0-3000 no load rpm. The corresponding impact rates are 0-1200, 0-3300, and 0-4000 impacts-per-minute (ipm). A built-in electronic digital keypad is used to select the desired speed/impact rate to match the application. The driver’s maximum torque is 2100 inch-lbs.
This new impact driver quickly sinks a variety of hex-shanked fasteners with rotational force (impacts), minimizing stripped screw heads. Because concussions are channeled to the fastener, there’s no residual effect on the user’s wrist or forearm. And with 2100 in.-lbs. of torque, the driver can manage the most demanding jobs.
The Nitro 20V impact driver weighs only 3.4 lbs. (with battery), and is powered by the same 2.0Ah MAX lithium-ion battery that powers up to 100 other WORX DIY and Lawn and garden tools and lifestyle products for cost savings and convenience. It has a built-in LED light that illuminates the work area when the trigger is pressed and signals a low-battery charge level when flashing. The impact driver has a variable-speed trigger and a comfortable GripZone rubber overmold handle grip.
The WORX Nitro 20V 3-Speed Impact Driver is capable of tackling multiple DIY, construction, assembly, and repair projects at home and the workshop, indoors and out.
