Line of IO-Link Analog Plugs provides a means to easily integrate analog I/O. By placing the IP67 plug between the standard analog field device and the IO-Link Master/Proxy, the plug converts the analog signal to a 14-bit resolution IO-Link signal, eliminating the need for an expensive multi-channel stand-alone IP67 or IP20 analog module. Further cost savings can be found by reducing the length of shielded cable, which is dependent on the grounding solution. Input and output versions are available in 4-20 mA and 0-10 volts.
Balluff
www.balluff.com/io-link
Filed Under: Electronics • electrical, I/O modules, Power supplies
