Depending on the version, Novotechnik, U.S. Vert-X 2800 Series of sensors measure angular position and convert rotational angle into an analog or digital output. Analog outputs options are 4 to 20 mA, 0.1 to 10 V, 10 to 90% of supply voltage and 5 to 95% of supply voltage. Digital output choices are SPI or PWM. Additional options include up to two programmable TTL-level switches.
Available in single and fully redundant versions, the magnetic sensor’s measurement range is 0 to 360° with repeatability of 0.1° and have up to 14-bit resolution and linearity to ±0.1 % of measurement range.
With packaging sealed to IP 65, the sensor’s life is ≥ 50 million movements and MTTF is over 100 years.
For more information, click here.
Filed Under: Sensor Tips
