Anomet Gold & Gold Alloy Composite Wire and Strip
By Anomet Products Inc. | June 21, 2016
Anomet Products, Inc. introduces custom manufactured composite clad metal gold and gold-alloy wire that is superior to electro-plated wire for a wide range of electronic applications.
Designed for use in micro-switches and rotary connectors, they are ideal for fabricating coils and hermetic devices. Typically incorporating 2% or more cladding thickness, they are uniformly dense and will not crack or flake. Sizes start at 0.002” (0.05mm) O.D.
Anomet Gold & Gold Alloy Composite Wire and Strip are typically 10 times less expensive than solid precious metal products.
Key Features
  • Anomet Gold & Gold Alloy Composite Wire and Strip are clad over copper and copper alloy substrates and metallurgically bonded featuring a smooth, consistent surface finish
  • Greater ductility and formability than electroplated products
  • Functionally equivalent to solid products
  • Conductive, solderable, formable, and corrosion-resistant
EXE014 - Image 1
