A full line of compact, air-powered single stage vacuum generators that are offered in a wide range of configurations for pick-and-place applications is available from Anver Corp. of Hudson, Massachusetts.
Anver JB Series Single Stage Vacuum Pumps are air-powered venturi style pumps that incorporate one-piece anodized aluminum bodies, brass internal nozzles, and achieve a 27‚†Hg vacuum with low flow rates from 1.2 to 9 CFM. Featuring an energy-saver version which has an air supply control valve, check valve and a fast-acting switch to maintain a programmed vacuum level, these modular vacuum generators are offered in a variety of standard sizes.
Allowing system builders optimum flexibility, Anver JB Series Single Stage Vacuum Pumps can be configured with electric or pneumatic pilots, supply and blow-off control valves, dual ports, mufflers, vacuum port extensions, gauges, and a host of other accessories. Ideally suited for pick-and-place applications, they are designed to be located close to the pickup point.
Filed Under: Pumps
