Hudson, MA – Anver Corporation introduces a new fail-safe, dual circuit vacuum lifter that incorporates two vacuum systems in one for handling high-value loads that absolutely cannot be dropped.
Anver’s Dual Circuit Vacuum Lifter features all-welded steel construction and is powered by two independent vacuum system circuits, including check valves for each, two separate reservoirs, and filters. Designed for high-value loads where a redundant system is desired, various sized beams, cross arms, and vacuum pads are offered and hooks are included for safety straps.
Custom built in capacities up to 60,000 lbs., Anver’s Dual Circuit Vacuum Lifter features hand-replaceable quick-change ring vacuum sealing cups.
It can be powered by either compressed-air or electric vacuum pumps and options include electric or hydraulic actuated powered tilting systems. Suction cup materials can be selected to match specific load requirements.
Anver’s Dual Circuit Vacuum Lifter is priced from $14,950.00 up, depending upon configuration and capacity. Pricing is available upon request.
Anver Corporation
www.anver.com
Filed Under: Automation components, Material handling • converting, Pneumatic equipment + components
