    • Subscribe!
Applied Motion Products Introduces ST5-Q Stepper Drives
By Design World Staff | September 24, 2007
(WATSONVILLE, CA) — Applied Motion Products introduces the ST5-Q Stepper Drive. The ST5-Q provides stand-alone operation and is quickly programmed with the robust Q programming environment, which delivers a number of benefits including register manipulation, conditional processing, math functions, multi-tasking and “generic” HMI compatibility.  The ST5-Q delivers up to 5.0 A with 24-48 VDC input, and provides 8 digital inputs, 4 digital outputs and 2 analog inputs.
Advanced stepper drive features allow the ST5-Q to obtain absolute maximum performance benefits from a stepper motor.  Self-Test and Auto Setup features measure and configure motor parameters automatically, while anti-resonance technology eliminates midrange instability for higher motor speeds and fuller use of available torque.  Demand Signal Smoothing reduces extraneous system resonances for smoother motor performance and reduced wear on mechanical components.  Torque Ripple Smoothing adjusts the current waveform to reduce low speed torque ripple for smooth motion at low motor speeds.  Additionally, MicroStep Emulation provides smooth motion for systems that require low step resolutions, such as retrofit systems with controller resolution that is fixed at a low value and cannot easily be changed.
http://www.applied-motion.com
Filed Under: Drives (stepper) + amplifiers, Motion control • motor controls, Motors • stepper
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
    • Subscribe!
