WATSONVILLE, CA, Applied Motion Products STAC6-Q Stepper Drives utilizing Q programming language‚ are now available with current output from 0.5 – 3.2 A with 220 VAC input and provide software selectable resolutions from 200 to 51,200 steps/rev at speeds up to 50 rps.
The Q programming environment provides options for downloading, storing and executing multiple programs with a single drive. It provides users with a number benefits including register manipulation, conditional processing, math functions and multi-tasking. Additional benefits include pulse and direction with electronic gearing, encoder following with electronic gearing, clockwise and counter clockwise pulse, as well as the ability to host interface while executing internal programs.
Additionally, these drives include Self-Test and Auto Setup features to measure and configure motor parameters automatically, while anti-resonance technology eliminates midrange instability for higher motor speeds and fuller use of available torque. Command Signal Smoothing reduces extraneous system resonances for smoother motor performance and reduced wear on mechanical components.
Torque Ripple Smoothing adjusts the current waveform to reduce low speed torque ripple for smooth motion at low motor speeds. Additionally, MicroStep Emulation provides smooth motion for systems that require low step resolutions, such as retrofit systems with controller resolution that is fixed at a low value and cannot easily be changed.
For more information contact: Applied Motion Products, 404 Westridge Drive, Watsonville, CA 95076; 1-800-525-1609; fax: (831) 761-6544; E-mail: [email protected]; Web site: www.applied-motion.com.
:: Design World ::
Filed Under: Drives (servo) + amplifiers, Drives (stepper) + amplifiers, Motion control • motor controls
