    • Subscribe!
ASM presents a compact magnetic angle sensor
By Editor | November 26, 2012
ASM presents the PRDS1, a compact magnetic angle sensor in M12 housing and sets new standards. The angle is measured without contact and wear-free over the entire measuring range up to 360° via a separate magnet.
From the POSIROT® family of magnetic angle sensors ASM presents an especially compact sensor. Only 12 mm in diameter and 50 mm depth the PRDS1 is suited to particularly compact applications where access is difficult. The complete measurement range of 0° to 360° is totally non contact utilising an independent magnet with an air gap between the sensor. This overcomes any connection or alignment problems often experienced if sensors have output shafts.
The PRDS1 has a range of incremental digital outputs RS5V, RS24V and HT24V with other alternatives being continuously developed. The sensor is manufactured from stainless steel with an integral M12 thread incorporated into the M12 body giving sealing options from IP67 to IP69K.
The compact designed PRDS1 angle sensor can be used for all applications where angle detection and angle monitoring is required, such as assembly lines, valve flap settings, packaging machines, medical equipment, etc.
ASM Sensors, Inc.
www.asmsensors.com
Sensor Tips
Filed Under: Sensor Tips
Tagged With: asmsensors
LPPS-36B Series Linear Potentiometer Position Sensor with Rod Ends
Hybrid sensors for connected vehicles
How are wearable systems improving?
Faster than any other IDS industrial camera: uEye Warp10 with 10GigE
    • Subscribe!
