Atomizing Spray Nozzle Provides 360 Degree Coverage
By Frank Tobe | March 8, 2016
EXAIR’s 1/4 NPT internal mix 360 degree hollow circular pattern atomizing spray nozzle atomizes fluid and sprays away from the nozzle in all directions. These nozzles are ideal where a smooth, even coating is needed on the inside diameter of a pipe or similar ductwork. They are also effective for operations where mist over a broad area is needed, such as dust suppression, humidification and cooling. They combine liquid and compressed air inside of the air cap to produce the finest mist of atomized liquid that can be easily adjusted to meet the needs of your application.
AT360circpat_pr3mb
These spray nozzles provide liquid flows from 1.6 to 8.9 gallons per hour. With EXAIR’s atomizing nozzles, you can coat, cool, treat and paint a variety of products using compressed air and liquids with a viscosity of up to 300 centipoise. They are commonly used with water, light oils, rust inhibitors, chemicals, paints and dyes.
The stainless steel construction of these atomizing nozzles adds to their durability and corrosion resistance. EXAIR atomizing nozzles are available with 1/4 NPT and 1/2 NPT connections and in a variety of sizes and shapes to meet your needs. All models are adjustable, come with our 5 year Built to Last Warranty and are CE compliant. Internal mix 360 degree hollow circular pattern spray nozzles ship from stock and start at $215.
EXAIR
www.exair.com/smat.htm
Filed Under: Aerospace + defense, TECHNOLOGIES + PRODUCTS, ALL INDUSTRIES
Tagged With: exair
Dual high-temperature Cabinet Cooler systems for large enclosures
china-manufacturing-future-image
Is China’s manufacturing future in trouble?
