Advanced Thermal Solutions, Inc. (ATS), a thermal engineering and manufacturing company focused on the thermal management of electronics, is pleased to announce the expansion of its line of high-performance, off-the-shelf, flat and round heat pipes. By the end of 2018, ATS will provide the broadest offering of off-the-shelf heat pipes on the market.
The application of heat pipes in the thermal management of electronics continues to grow significantly and ATS high-performance copper heat pipes with grooved or sintered, copper powder wick structures are the perfect solution for cooling a variety of applications across numerous industries, including aerospace, medical, consumer electronics, telecommunications, HVAC, and more.
Thanks to a state-of-the-art, on-site testing process in its new heat pipe lab, ATS ensures the reliability and expected thermal performance of all the heat pipes that it offers.
ATS is expanding its flat and round heat pipe offerings from 33 to more than 350. Round heat pipes will be available in lengths of 70-600 mm and diameters of 4-10 mm, while flat heat pipes will be available in lengths of 70-500 mm, widths of 4.83-11.41 mm, and heights of 2-6.5 mm.
Before considering costly custom heat pipe dimensions, which can add time as well as money to a project, engineers should explore the extensive array of off-the-shelf options that ATS will offer in its expanded line to find the right fit to meet their specific thermal performance and space requirements. ATS heat pipes are the perfect option to add to your cooling assembly.
To make the selection process easier for engineers, ATS has created a Heat Pipe Selection Tool. Simply input the desired criteria, including length, wick type, heat to be dissipated, evaporator insertion length, and condenser insertion length, and calculate the right fit for your design. The selection tool can be found at https://www.qats.com/Products/Heat-Pipes.
In addition, to further reduce the cost and time of engineering a heat pipe solution, ATS has produced an Engineering eBook that covers the technology and application points of heat pipes in the thermal management of electronics. The eBook is available for free download at https://www.qats.com/cms/engineering-ebooks.
www.qats.com
Filed Under: Electronics • electrical
