AttaBox Enclosures Introduces the Freedom Series
By AttaBox | February 20, 2018
AttaBox has now released a product that has a full, water-tight seal that protects against the outside environment. These enclosures are both flexible and aesthetically pleasing. The Freedom Series is unique because the enclosures allow the user to use only features required for their specific application. These products are made of fiberglass-reinforced polyester in order to work for diverse applications, including high-end electronics, OEM housings, and conspicuous industrial applications.
Features Include:
  • Available in two cover options:
1.  Opaque cover
2.  Flush bonded window
  • Maximum visibility to raised panels and control devices
  • High temperature, flame retardant, non-corrosive environmental designs
  • Stands up to an exceptionally broad range of chemical exposures
  • Results in an environmentally-sealed environmentally sound space
  • High impact resistance
  • Non-metallic material prevents electrical shock
  • Solid construction in a lightweight design
  • UV resistance, featuring patented SolarGuard®, which protects against UV degradation
For more information, visit AttaBox’s website at https://attabox.com/product-category/enclosures/freedom/
PCB mills
