Auburn Bearing launches new mounted thrust bearing solution
By Mike Santora | June 17, 2019
Auburn-Bearing-MT-114-RG-0010 3D DrawingAuburn Bearing & Manufacturing has announced its new and exclusive MT-114-RG mounted thrust bearing. The MT-114-RG is a bearing assembly that allows Auburn Bearing’s  T-114-RG style thrust bearing series to be conveniently threaded onto a shaft for mounting or to be bolted into place. This bearing and mount combination allows for fast and easy mounting of this small, self-contained thrust bearing.
The new MT-114-RG can be installed using a variety of mounting configurations, including bottom thread mounting, shoulder mounting, and lock nut mounting, making this bearing and mount assembly a convenient solution for a variety of applications that require the T-114-RG style thrust bearing.
Key Features:
• Designed to mount ABM’s T-114-RG thrust bearing
• Supports an unusually high load capacity
• Allows for quick and easy installation
• Manufactured in the USA
• Custom sizes and materials available
• Free application support
www.auburnbearing.com
Filed Under: Uncategorized
Tagged With: auburnbearing
