A Fatigue Wizard was added to Autodesk’s Algor-based simulation software. It helps you to predict fatigue-based failure and subject products to cyclic stresses. The software provides step by step guidance through the process of setting up a fatigue analysis.
You can choose between stress-and-strain based analysis types, specify material information using an extensive, editable database, and enter data to simulate real-world conditions. Fatigue Wizard functionality is available through an Autodesk Subscription Advantage Pack for Autodesk Algor Simulation 2010. Autodesk Algor Simulation software’s multi-CAD The Fatigue Wizard has been added to Autodesk’s Algor simulation software. interoperability applies to Fatigue Wizard.
Autodesk
www.autodesk.com
Filed Under: FEA software, Simulation, Software
