The EL3602 Ether-CAT‚® I/O terminal,for use with EtherCAT, samples measurement readings with a 24 bit resolution and accuracy within ‚±0.01%.
It measures signals directly in a standard I/O system. The analog 2-channel EL3602 input terminal handles signals between -10 and +10 V. The voltage is digitized with a high, 24-bit resolution. The high precision of ‚±0.01% at 25 ‚°C lets you perform high-precision measuring tasks on a machine or for test rig automation, for example.
Beckhoff Automation, LLC
.:Design World:.
Filed Under: Ethernet — cables • hubs • switches, CONNECTIVITY • fieldbuses • networks • gateways
