Omega introduces its new MPS40 series of automatic melting point, with touch screen display, that uses the latest technology in digital image processing to accurately identify the melt of up to 3 samples simultaneously. The CE compliant MPS40 series has an innovative split design concept, the unit can be used as normal or the control side and the melt side can be separated, allowing for the maximum in footprint flexibility. Maximum temperature is 400 degrees Celsius (752 degrees Fahrenheit) and integrated cooling 350 to 50 degrees Celsius (662 to 122 degrees Fahrenheit) in 10 minutes. All units are supplied with a NIST calibration certificate showing individual serial numbers. Ideal for Chemical, Industrial, R&D and labs.
Omega Engineering
www.omega.com
Filed Under: TEST & MEASUREMENT
we want to procure one automatic melting point apparatus. handling the order through agent in india will be easier. plese let us know if you have agent in india
thanks asnd regards
jyotirmoy das
[email protected]
