Starting immediately, automation professionals can obtain terminal blocks from automation24.com. The online shop offers Universal Range Terminal Blocks from Weidmüller with PUSH IN technology or with screw terminals. These modular terminal blocks have a streamlined design, high mounting density, copper power rails, and large marking surfaces to support efficient installation and maintenance.
Terminal blocks for all applications
The terminal blocks offered cover all connection requirements in an electrical enclosure such as PE, Fuse, Feed-through, Multi-tier, Test disconnect, and Neutral conductor disconnect terminal blocks. Newly added, Weidmüller’s Klippon Connect Universal Range terminal blocks include the A-series PUSH IN spring connection type and the W-series clamping yoke screw connection type. Terminals are offered from 6.3 amps to 269 amps and up to 250 MCM wire. In addition to being robust and reliable, they are designed to be clearly arranged and easy to use.
For a limited time, Automation24 is offering Weidmüller Thermal MultiMark Printers for only $1.00 with a qualifying purchase of marking consumables/accessories. The THM thermal transfer printer offers a compact solution for a variety of print jobs and provides a simple solution for manufacturer-independent terminal marking.
Automation24
www.automation24.com
Filed Under: Terminal blocks
