AutomationDirect Adds Air Pilot and Manual Control Valves to Product Line
By Design World Staff | May 14, 2012
The NITRA® line of pneumatic products has been extended to include air pilot valves, foot pedal valves, and manual control valves.
The AVS-5 series now includes single and double-pilot directional control air pilot valves, offering spring return or center closed operation. All are body ported five-port (four-way) spool valves and are available in 1/8” to 1/2” NPT port sizes with flow coefficients from 0.67 to 2.79. AVS-5 series air pilot valves start at $14.
NITRA CVS series directional control foot pedal valves are five-port (four-way) spool valves designed for non-electrical operator control applications. Available in momentary or latching operation models, foot pedal valves feature a 1/4” NPT port with a flow coefficient of 0.80. CVS foot pedal valves start at $25.50.
Manual valves in toggle-style hand lever, push-pull, and rotary-style hand lever models have also been added. Constructed with aluminum alloy bodies, available port sizes are 1/8” to 1/2” NPT with flow coefficients from 0.78 to 5.29. Starting at $14, models are available in two or three-position detented styles.
The NITRA manual valves can be seen by visiting: www.automationdirect.com/manual-air-valves. More information for NITRA air pilot valves is available at: www.automationdirect.com/air-pilot-valves.
AutomationDirect
Filed Under: Pneumatic equipment + components, Valves
Comments
  1. Anand Radhakrishnan says
    August 28, 2012 at
    The options in manual control, the toggle style, the foot pedal and many others along with the all aluminium body construction makes it stand out.
