AutomationDirect has added more FATH hardware components to its selection of T-slotted rail products. These components easily install in SureFrame rails, as well as many other brands, and include roll-in T-slot nuts with spring loaded ball, slide-in T-slot nuts, screw and miter connectors, 1- and 2-slot pivot joints, extended swivel bases, foot consoles, leveling casters, magnetic catches, sensor mounting blocks, protection profiles, profile sliders, roller elements, and more.
Also added is a 4-axis workstation and workstation components which allow PC monitors and peripherals to be mounted near the equipment. Components include swivel monitor mounts, monitor mounting joints, multi-axis mounting supports, and many other accessories.
New panel holders and panel mounting blocks are also available for wire mesh or solid machine guarding. These holders and mounting blocks allow the installation of machine guarding to protect equipment and personnel from damage and injury.
The new FATH T-slotted rail hardware components start at $2.00 and come with a one-year warranty.
AutomationDirect
www.automationdirect.com
You may also like:
Filed Under: FASTENING • JOINING • locks • latches • pins
