    • On the Floor
AutomationDirect adds Jefferson Electric Buck-Boost Transformers
By Design World Staff | March 1, 2012
AutomationDirect’s power product line now includes buck-boost transformers from Jefferson Electric. Buck-boost transformers are designed to maximize the performance and life of electrical equipment, such as air conditioners, heating elements, 277-volt lighting systems, and in motors applications. Also called an isolation transformer, typical use is to power loads with specific voltage requirements which differ from the available line voltage.
Jefferson-Buck-Boost-Transformers
Jefferson Electric 60Hz single-phase buck-boost transformers, with 50VA to 2kVA ratings, are encapsulated with electrical-grade resin, featuring high-quality electrical steel cores. The NEMA 3R-rated enclosures are heat-cured with an ASA-61 gray powder coat finish and have slotted mounting holes for quick and easy mounting.
A buck-boost transformer can have two main applications. When connected as an auto-transformer, you can buck (lower) or boost (raise) available line voltage anywhere from five to 20 percent. When used as an isolation transformer, it can be used to step-down supply power to low voltage circuits at the nameplate rating listed.
Buck-boost transformers start at $53 and are UL approved and are backed by a 10-year limited warranty.
AutomationDirect
www.automationdirect.com/buck-boost-transformers
Filed Under: Factory automation, AUTOMATION, ELECTRONICS • ELECTRICAL
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
