AutomationDirect adds Magnetic-Inductive Flow Meters
By Frank Tobe | November 6, 2015
AutomationDirect’s ProSense line now includes magnetic-inductive flow meters. Magnetic-inductive flow meters (magmeters) are one of the most widely used technologies for liquid flow monitoring in industrial processes such as wastewater, mining and minerals, utilities, food and beverage, and pharmaceuticals.
The FMM series magmeters, available with 1/2” to 2” NPT female process connections, are designed with a 4-digit numeric display with pushbutton setup, a 4-pin M12 quick disconnect and two outputs. The stainless steel, mechanically-robust design mounts directly in-line providing a compact, low-profile installation for process control. Simple to set up, easy to install and with no moving parts, the FMM is a reliable alternative to traditional flow meters and mechanical flow switches.
The ProSense FMM series (-1001) magmeter is designed to detect the flow rate of conductive media up to 160 gallons per minute. The 4-digit numeric display indicates flow rate, fluid temperature and total flow volume with selectable engineering units (GPM, GPH, GAL, °F, °C). Two outputs, selectable for switch, pulse, frequency or analog signals, are available to remotely monitor the binary or analog status of flow rate/volume and temperature parameters.
AutomationDirectProSense FMM series (-1002) magmeters are designed to detect the flow rate of conductive media up to 158.5 gallons per minute. The 4-digit numeric display indicates flow rate and fluid temperature with selectable engineering units (GPM, GPH, LPM, m³/h, °F, °C). Two analog outputs are available to remotely monitor flow rate and temperature parameters.
Backed with a five-year warranty, ProSense FMM series magnetic-inductive flow meters start at $460.00.
AutomationDirect
www.automationdirect.com
Filed Under: TECHNOLOGIES + PRODUCTS
Tagged With: automationdirect
Rockwell Automation offers new online capabilities with industrial automation software
NYE adds Vishay Miniature Position Sensor to product lineup
05-P16-Gen-1-Lifestlye-M&E
Lenovo introduces ThinkPad P16
ADISRA InsightView-IV_main_dash2
ADISRA InsightView delivers advanced equipment analytics
