    • Subscribe!
AutomationDirect Adds NEMA-rated Stratus™ Air Conditioners for Enclosures
By Patrick Curran | August 27, 2010
Cumming, GA — Heat inside an enclosure can decrease life expectancy in controlling units such as PLCs, HMI, and AC drives. Excessive heat can cause nuisance faults from electrical and electronic components, circuit breakers and fuses. To help alleviate such problems, AutomationDirect has added NEMA-rated Stratus™ air conditioners for enclosures.
adc-industrial-air-conditioners
These closed-loop cooling systems are recommended for harsh environments, or when there are washdown requirements, heavy dust and debris, or airborne chemicals present. Available in 120V and 230V units, the NEMA 12, 4 and 4X-frame Stratus 1,000 to 8,000 BTU/H air conditioners feature free-standing rigid chassis for easy installation and maintenance. NEMA 12 and 4 models are constructed of 16-gauge cold rolled steel; NEMA 4X units are made of 16-gauge 304 stainless steel. All units contain an active condensate management system and protective-coated condenser coils.
Designed to fit enclosures as shallow as 12 inches, each unit features a digital LED temperature controller with visible alarm and is pre-wired for external alarm monitoring. The highly energy-efficient compressors are charged with CFC-free refrigerant and equipped with anti short-cycle protection. All models are UL and cUL listed. Prices start at $1,099.
AutomationDirect
www.automationdirect.com/enclosure-cooling
Filed Under: Factory automation, Cabinets • enclosures • control panels, Electronics • electrical
molex-premo-flex
    • Subscribe!
