AutomationDirect Adds Pneumatic Air Cylinders
By Dave Miyares | August 24, 2009
AutomationDirect has extended its NITRA™ pneumatic product line to include a series of stainless steel, round body, non-repairable cylinders.
The new cylinders feature type 304 stainless steel bodies with double rolled-in construction with high-strength aluminum alloy porting ends. Single and double acting models are available with nose, pivot and double-end mounting options. Certain cylinder models are also available with magnetic pistons for position indication. This series includes bore sizes from 7/16 inch up to 2 inches; depending on bore size, available stroke lengths range from ½ inch to 18 inches. NITRA pneumatic air cylinders are ideal for many applications such as packaging lines, conveyors, material handling and robotics.
The complete line of NITRA non-repairable pneumatic air cylinders can be seen by visiting: www.automationdirect.com/pneumatic-cylinders-disposable..
AutomationDirect
Filed Under: Pneumatic equipment + components, FLUID POWER
