AutomationDirect’s STRIDE communication products provide reliable connectivity to industrial controllers and field devices. The STRIDE Field I/O family of modules provides a simple and economical means to connect inputs and outputs to a Modbus TCP communications network via Ethernet 10/100 Base-T. Each module operates as a standalone Modbus TCP server, and can be remotely configured via a built-in web server.
STRIDE Field digital I/O modules provide up to 16 discrete inputs each with options for discrete and relay outputs. STRIDE analog input modules are available with up to 8 current (-20 to +20 mA) or voltage (-10 to +10 VDC) inputs. Analog output modules provide four 0-20mA/0-10VDC output channels. STRIDE temperature modules provide 4 or 8 thermocouple inputs or 4 RTD channels per module.
Starting at $139.00, STRIDE Field I/O modules from AutomationDirect are UL listed / CE marked and have a 2-year warranty.
AutomationDirect
www.automationdirect.com/stride-io
Filed Under: I/O modules
