AutomationDirect’s ProSense line of process sensors now includes temperature switches, temperature transmitters and RTD temperature probes.
The TSD25 series switches offer dual output setpoints over an operating temperature range of -13 to 284°F. With 4-20mA analog outputs, the TTD25 series of transmitters provides a compact temperature monitoring system over temperature ranges from 0 to 100°C or 0 to 300°F. The four-wire, 100 ohm platinum RTD probes are made of durable 316 stainless steel and measure temperatures ranging from -40 to 302°F. The 10 mm diameter probes are available in lengths from 160 mm to 560 mm. Thermowells and fittings are also available.
Filed Under: Sensors (temperature), Test + measurement • test equipment
