    • On the Floor
  • Advertisers
    • PR Submissions
    • Eblast Submissions
AutomationDirect adds WEG IEC contactors, starters, safety gear
By Srabanti Chakraborty | December 30, 2025
AutomationDirect has added WEG Electric CWBN series contactors that are IEC-compliant and NEMA-rated, delivering robust, dependable performance in a compact IEC-style housing. They are offered at a highly competitive price, in ratings from 2 to 50 hp (95A) at 460 VAC, and meet or exceed the electrical requirements defined by NEMA ICS 2 standards for full- and reduced-voltage motor starting.
WEG Electric ESWE series Type F combination starters feature a non-metallic NEMA 4X enclosure for protection in harsh environments. They include a manual motor protector that serves as the disconnecting means and an IEC contactor, factory coordinated for short-circuit and overload protection with full motor control in a single assembly. These full-voltage, non-reversing starters are rated from 1/2 to 20 hp at 460 VAC (38A) and provide flexible options for motor starting and control.
Additional WEG CWBS series IEC safety contactors feature contact ratings up to 125A, mechanically-linked and mirror contacts, electronic coils with wide 24-60 VAC/VDC or 110-255 VAC/VDC input ranges, and they comply with IEC and UL standards.
More WEG RWB40E series electronic overload relays are offered in ratings up to 40A and feature remote reset capability via a 24 VDC input from an external pushbutton or PLC output. These self-powered overload relays mount directly on WEG CWB/CWBN series contactors and protect motors in low-, medium-, or heavy-duty applications via DIP switch-adjustable trip class settings.
For more information, visit automationdirect.com/motor_controls.
Filed Under: Relays
Tagged With: automationdirect
Srabanti Chakraborty has been associated with engineering.com as an editor for the last ten years. She holds a Bachelor of Arts and has completed specialized professional courses such as eDAST from CMC and the CCNP networking course. A regular reader of science journals, she stays informed about the latest advancements in AI and space research.
  • Siemens aims for 80 percent automation in German plant
  • Humanoids building humanoids, and new robots for agriculture equipment in Kansas
  • Amazon takes on another industry: robotics
    • On the Floor
  • Advertisers
    • PR Submissions
