AutomationDirect now offers the innovative Weidmüller UR20 remote I/O system which is a modular, space-saving system that combines flexibility with industry-leading ease of use to improve I/O performance and availability. The UR20 fieldbus coupler can be quickly set up using the built-in web server interface, no software download required. Once installed, connections to other devices are quick and simple with removable, color-coded push-in connectors and an I/O bus that provides DC power to up to 16 modules. The fieldbus couplers offer popular industrial protocols including PROFINET, EtherCAT, Modbus TCP, and EtherNet/IP with dual RJ45 ports (10/100 Mbps) that support a daisy-chain topology without the need for an external switch. A wide range of I/O options is available including digital I/O (8 or 16 channels), relay outputs, analog inputs, temperature inputs, and load cell inputs. Other modules include power-feed and filler modules, and a 4-port IO-Link master can also be added for added peformance tracking and diagnostic information. Status LEDs on the UR20 modules make it quick and easy to verify operation and diagnose issues, helping with troubleshooting and reducing downtime.
For more information, visit automationdirect.com/field_i-z-o.
Filed Under: CONNECTIVITY • fieldbuses • networks • gateways
