AutomationDirect has expanded its Hammond line of HPS Fortress commercial encapsulated power transformers. The single phase units are now available in 100VA up to 25kVA ratings and input voltage ranges of 120VAC to 480VAC. All units are encapsulated with electrical grade silica sand and resin compounds to protect the core and coils, sealing out moisture and airborne contaminants and eliminating corrosion and deterioration.
The NEMA 3R enclosures meet or exceed NEMA and ANSI standards for indoor and outdoor applications, and are UL and CSA listed as well as CE approved. The Fortress series encapsulated power transformers are backed with a 10-year limited warranty. Prices start at $77.
AutomationDirect
www.automationdirect.com/power-transformers
Filed Under: Factory automation, Automation components, Electronics • electrical
