Cumming, GA —AutomationDirect has added to its line of wire stripping and crimping tools. The new self-adjusting cut-and-strip tool features the widest stripping capacity of any tool of its type, cutting flexible wires up to 8AWG and rigid wires up to 16 AWG. Easily interchangeable stripping cassettes, color coded by blade type, are available for stripping a wide range of most modern insulation types, from PVC to PTFE.
A new cable stripping tool removes insulation from copper and fiber optic audiovisual, data transmission, instrumentation, signal, and telephone cables up to 11mm and insulation up to 1 mm. Its precise, nine-position blade height adjustment wheel provides for fine adjustability and repeatability. Replacement blades are also available. Also available is a crimping tool series with handle and die sets for various wire sizes and terminal types.
www.automationdirect.com/tools
