AutomationDirect® has extended its sensor cable offering to include quick-disconnect and patch cables with LED indicators. The new patch cables have a right-angle M12 female plug with LED indicator on one end and an axial male connector on the other.
Available in six lengths ranging from 0.3m to 10m, the cables feature a polyurethane jacket for dependable use in oily and direct sunlight applications. Prices for patch cables with LED indicators start at $10.75. Also added are quick-disconnect cables with an LED indicator to confirm signal presence. Fitted with industry standard M12 right-angle female plugs, these cables can be used with patch cables to extend distance. Available in two-meter, five-meter and 10-meter lengths, these cable prices start at $10.75.
AutomationDirect
www.automationdirect.com/cables
Filed Under: Factory automation, Cables + cable management, Electronics • electrical, Motors • stepper, Sensors (position + other), Test + measurement • test equipment
