AutomationDirect has added the BLOCK PM series mini power supplies, which feature a compact form factor, sufficient transient voltage protection, and an affordable price. They are robust and adaptable for various applications, offering performance and reliability without the higher cost of full-featured power supplies.
The new BLOCK PM-0624-100-0 redundancy module prevents costly downtime by monitoring two matched BLOCK power supplies and switching to a backup when a failure occurs. The module also decouples the power supply outputs to prevent one supply from overloading the other.
BLOCK PM series power supplies offer 24 to 96 W models with 12 or 24 Vdc adjustable outputs and start at $49.50; the BLOCK PM redundancy module accepts power supply inputs up to 144 W and is priced at $98.00.
You may also like:
Filed Under: Power supplies
