AutomationDirect’s Current Sensing Line Expands
By Design World Staff | April 1, 2011
The GFS series of ground fault sensors monitors all current-carrying conductors in grounded single and three-phase delta or wye systems. Available in fixed-core models, the GFS series features jumper-selectable setpoints of 5, 10 or 30 mA. The sensors can accommodate up to 14 AWG copper wire and feature mechanical relay outputs with either manual or auto reset. The UL and CE approved GFS series of ground fault sensors start at $136.
AutomationDirect Sensor Line
The DCT series of DC current transducers combines a Hall Effect sensor and signal conditioner into a single package for use in DC current applications up to 400A. Designed to be compatible with most PLCs, data loggers and SCADA systems, the DCT series features jumper-selectable current input ranges and industry standard 4-20 mA or +/- 10 VDC outputs. Available in split-core or fixed-core models, DCT current transducer prices start at $117.
DCS100 series DC current switches feature jumper-selectable current input ranges up to 100A and are available in normally-open solid-state and SPDT relay output models. The switches are equipped with removable terminal blocks which accept up to 12 AWG solid or stranded wire. Prices for DCS100 DC current switches start at $90.
All acuAMP sensors are panel-mountable; convenient DIN rail adaptor accessories are also available.
The complete acuAMP series offers outstanding features, flexibility, and durability. Backed with a five-year warranty, the complete line of current transducers and switches provides dependable service for virtually any application.
AutomationDirect
www.automationdirect.com
Filed Under: Factory automation, AUTOMATION, SENSORS, Switches, TEST & MEASUREMENT, Terminal blocks
