Seasonal repairs, particularly to vehicles, can be made easier with the correct tools and ideal components. Snap-on Incorporated, a U.S. manufacturer and marketer of high-end tools and equipment for professional use in the transportation industry, offers a few suggestions for spring automotive repairs.
Snap-on’s Filter Spider Wrench.
Blue-Point (a Snap-on brand) OFCA3HDKT 75-153 mm Spider Filter Wrench with Adaptor. This spider-filter wrench is ideal for lower-clearance work on a range of oil filters, including those in tight spots. The heat-treated, longer legs are sharpened to better engage and the chrome plated finish cleans easily after use. It has an expanded range of 73 to 153 mm and comes with a 3/8 to 1/2-inch drive adaptor.
The Snap-on HDP1835 Harmonic Damper Pulley Puller. This revolutionary design increases the bite of the side-turned leg to the pulley as it’s being tightened, which allows it to be used in a wide array of applications. The unique geometry increases its versatility and pulling power, saving technicians up to 30 minutes when working on the engines of GM Chevrolet Camaro 3.6L, 2018 Ford Mustang Coyote, 3.0L Duratech and several other models.
The HDP1835 is now more versatile and has a broader range of uses, and the compact design accommodates tight engine compartments.
Snap-on PACKRPDKIT Restore/Polish/Detail Kit. Springtime’s environmental residue is less likely to damage a vehicle’s finish when it’s protected with PACKSEALANT Ceramic Coating Spray Sealant.
The product:
- Covers up to six full-sized vehicles for up to one year
- Is silicone-free, and leaves no powder residue.
- Is water-based
The starter bottle comes in a detail kit that contains PACKLQDPLSH Liquid Polish that is non-abrasive and removes tarnish, rust, and water stains. It’s non-flammable, non-toxic and works on all metals, fiberglass, plastics, glass and painted surfaces.
The kit also comes with a PACKBB3 3″ viscose Fabric Buff Ball, PACKTBP3P 3″ Polishing Turbo Buff Pad, PACKSD31000 3″ Abrasive disc 1000 grit, PACKEXT4PP 4″ Extension Shaft for the Buff Ball, and KACKMCFIBER1 Microfiber cloth.
Filed Under: Automotive
