The AV system from AVENTICS is a complete automation solution offering clear advantages for production systems. The AV system continuously adapts to the users’ requirements and maximizes the potential of existing machines.
Comprehensive flow analyses, a modern polymer-based construction, and AVENTICS’ many years of experience with application requirements were the basis for this manifold concept. This resulted in a significantly reduced weight and extremely compact size result in an increased function density.
Flexible use of the valve system – AV03 and AV05
The diagonal spool, flexible base plate, and galvanic isolation in the power concept are all characterized by their adaptability and simplicity. Up to 64 base plate valves can be added modularly to the board, and configurable voltage and compressed air circuits add to the system’s flexibility.
AES – open for any connection
An optimum combination of directional valves with the AES fieldbus connection and a large variety of components is a decisive advantage. As a fieldbus connection, it ensures optimum communication between actuators and machine peripherals. In combination with the compact AV systems, AES components can be placed very close to pneumatic drives.
Aventics
www.aventics.us
Filed Under: Valves, Pneumatic Tips
