The AV850 8.5″ FC-face modular magnetic encoder from Avtron Industrial Automation is designed to eliminate encoder failure and drive trips.
The self-tuning electronic sensors have full built-in diagnostics, to warn of any problems before they stop your process. The 4X larger rotor-to-sensor gap makes installation simple, and eliminates scraped rotors. The wide rotor permits the AV850 to keep working even with large motor shaft movements, or less-than-perfect installation. There are no wearing parts or bearings. AV850 magnetic sensors are fully sealed against dirt and liquids, protected from wiring errors, and operate from -40ºC to +100ºC. Resolution up to 4096 PPR is available (single or dual independent outputs), offering high precision in tough applications.
www.avtron.com
Filed Under: Encoders (rotary) + resolvers, Motion control • motor controls
