Availability of Three New Sensors
By Randy Frank | August 27, 2012
With the recent acquisition of three product lines from Everight Sensors Corporation, H. G. Schaevitz LLC Alliance Sensors Group has expanded its sensor product offerings.
The PG Series of Power Generation LVDT Linear Position Sensors have a 3/8 inch diameter core extension rod making it twice the diameter of typical LVDTs. The sensors are rated for up to 350°F (175°C) operating temperature.
For more information about the PG Series of Power Generation LVDT Linear Position Sensors, click here.
The S1A LVDT/RVDT Signal Conditioner is a DIN Rail Mounted unit with a choice of 1, 3, 5, or 10 kHz nominal excitation frequencies and 40 dB range of FS outputs from LVDTs with 50 mV rms to 5 Volts rms.
For more information about the S1A LVDT/RVDT Signal Conditioner, click here.
The Linear Position Sensor MR-7 Series has a measurement range (linear) of 4 inches – 30 inches (100 mm – 750 mm) and non-linearity ≤ ± 0.25% FSO with ≤ ± 0.10% FSO optional.
For more information about the LVIT Linear Position Technology, click here.
Sensor Tips
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, Sensor Tips
Compact direct drive actuator boasts 1.25μm resolution
TMR magnetic sensors optimized for current, position sensing
Tiny dual-port pressure sensor simplifies design of PAP devices
AI/ML-based sensor fusion technology platform targets home-security alarm system
