Axiomtek’s GOT-3126TL-830 features a heavy-duty metal enclosure, ideal for the industrial environment. With a 12.1-inch SVGA TFT LCD that has a brightness of 450-nit and an Intel® Atom™ processor N270 1.6 GHz, this system provides excellent computing performance and thermal resistance for industrial environments. This fanless yet rugged platform is especially designed for operating in heavy-duty applications including steel refinery, oil pipeline, ship, machine manufacturing plant and many more. Three key features make the GOT-3126TL-830 a robust and cost-effective solution; wide operating temperature, anti-vibration, WLAN antenna (optional).
Wide Operating Temperature
The GOT-3126TL-830 features operating temperature range of -10°C to +55°C. It incorporates compact ID and a fanless cooling system with a low power Intel® Atom™ processor N270 1.6 GHz, making the platform a power-efficient solution.
Anti-vibration up to 1.3G
With a patent of anti-vibration design, the GOT-3126TL-830 works under 1.3G (5 ~ 500Hz, random for 2.5” HDD) during operation mode. The patent improves system reliability and sustainability.
WLAN Antenna Supported (optional)
The GOT-3126TL-830 has a PCI Express Mini Card slot for optional add-ons such as wireless LAN card for 802.11 b/g connections & 3G/GPRS application, dedicated video card, universal analog TV/FM tuner/AV capture card, and more. An optional fixed rotational WLAN antenna for wireless network connection is also available.
Additional Features
The 12.1-inch touch panel computer GOT-3126TL-830 utilizes one 200-pin DDR2 533 SODIMM system memory max. up to 2GB, one SATA HDD and one CompactFlash™ slot. It provides over-current protection fuse and a full set of I/Os including three RS-232 ports, one RS-232/422/485 port, four USB 2.0 ports, one audio (line-out), one Gigabit Ethernet and one VGA connector. Additionally, this slim unit supports panel mount, wall mount, VESA arm and desktop stand (optional).
The Atom™-based fanless HMI GOT-3126TL-830 will be available around the middle of February 2011.
Axiomtek
www.axiomtek.com
Filed Under: Electronics • electrical, HMIs • operator interfaces • monitors
