Baldor Electric Co. Introduces Dodge D-LAG Conveyor Pulley
By Stacy Combest | June 21, 2013
Baldor Electric Company introduces Dodge D-LAG conveyor pulleys, a line of stock conveyor pulleys than can lower total D-Lag-Conveyor-Pulleycost of ownership. D-LAG conveyor pulleys utilize a cutting edge natural rubber compound that is 73 percent more resistant to wear than standard SBR rubber.
By increasing lagging life, Baldor’s Dodge D-LAG conveyor pulleys will extend the operating life of both the conveyor pulley and conveyor belt. The lagging is 100 percent vulcanized for pulley bonding and strength, making it resistant to cuts and gouges.
Two pulley styles are available from stock for next day delivery; D-LAG heavy-duty drum pulleys from 10” to 24” diameter, and D-LAG MDX (mine duty extra) drum pulleys from 12” up to 24” diameter. Baldor’s Dodge heavy-duty pulleys are designed with flexible end discs to eliminate weld fatigue under cyclical loads, while Dodge MDX pulleys feature an integral hub design that eliminates the welded hub.
Independent testing in 2012 showed D-LAG significantly outperformed other rubber formulas when subjected to abrasive conditions.
www.baldor.com
Filed Under: Factory automation, Conveyors, Electronics • electrical, Motion control • motor controls
Tagged With: baldorelectric
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
