Banner Engineering EZ-LIGHT™ TL50 Beacon Tower Light
By Design World Staff | January 4, 2012
Banner Engineering Corp. announces the addition to its line of lighting and indicators, the EZ-LIGHT™ TL50 Beacon Tower Light-a hybrid of the company’s popular TL50 Tower and K50 Beacon lights. Similarly to Banner’s alternative TL50 models, the Beacon Tower is segmented and may be ordered with up to four different colored LED lights-red, yellow, green or blue-which allows several messages to be conveyed at once. These segments can easily flash or rotate their extremely bright signals, in addition to displaying a solid ON indication.
“We see tower lights as an important solution for so many industrial settings, and our TL50 is one of the most versatile indicator lights we’ve developed,” said Chuck Dolezalek, Product Development Manager at Banner Engineering. “Not only is it ideal for both indoor and outdoor applications because of its brightness, but the availability of audible and sealed audible models allows it to be used in a wide range of environments and applications.”
The extremely bright output of the LED beacons provides easy-to-see indication from all directions when multiple lights may need to be ON simultaneously-allowing operators to effectively monitor equipment from a distance. TL50 audible models with easily adjustable sound intensity are available, in addition to multiple bracketing options, enhancing the Beacon Tower’s functionality and placement options. Furthermore, the TL50 Beacon Tower has a wide 12-30V dc operating range, enabling it to be used in battery-powered mobile applications.
All of Banner’s EZ-LIGHT Tower Lights come completely preassembled and preconfigured, saving time and money in the installation process. Equipped with LED technology, these lights reduce power consumption, making them an energy-efficient solution. Both the general purpose and audible models of the TL50 Beacon Tower use Euro integral quick disconnect (QD) connectors, while the robust design of the indicator allows for direct machine mounting.
Banner Engineering
www.bannerengineering.com
Filed Under: Electronics • electrical, Lights • signal lamps • indicators
molex-premo-flex
